Modicon BME NOC 0103 fw type
doomsword
Aug 2016
Zagreb
201
I'm doing my first project with Modicon PLC, M580 PLC.
So I have one PLC for testing, along with one NOC card (it's just for few days testing, just to familiarize with Unity Pro sw and Modicon PLCs).
In hw configuration it's defined with firmware v2.05 while it seems I have v2.04. I try to find an option to change it in hw configuration to match fw to what I really have (don't want to update fw on a card). I cannot find it.
When I delete a card and put correct one I also delete some network configuration attached to it. Making me have sw that can't be compiled afterwards. :ROFLMAO:
So, how I keep all configuration already done for this module while changing it to correct firmware?
Also, any tips for Modicon PLCs are appreaciated (I have experience with Siemens).
Your version of Unity must only support that version firmware as a minimum. You could try using an older version of Unity.
There is a hardware compatibility chart in the Unity Help file.
Why not just update the firmware? It's pretty easy - should only take you 10 minutes.
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
50
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
58
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
300
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
95
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
247
