Modicon DAU-204
curthibbert
May 2008
Western Oklahoma
Hello!
I have a machine using a Modicon 984-285 processor. Several racks of I/O. My question concerns a DAU-204 analog output module that was replaced recently. As far as I can tell, you set up the configuration ie 1-5, 0-10, 4-20 in the traffic cop. On this particular module channels 1 and 2 are set up for 0-10, 3 is not used and 4 needs to be set up for 4-20ma. The first 2 channels are working okay, but the 4th is not putting out 4ma. It is at 0ma. So, I assume it is still at voltage no matter what the traffic cop says it is set at. Is there set up (dip switches)on the module also? I didn't see any. Do you actually have to reload the program to the processor when you change a module or something like that?
I know this is ancient history, but I would appreciate any help.
regards,
Curt
Hello everyone. I am having trouble trying to find out what the dipswitch settings on a Modicon AS-BDAU-204 are for. The card is a 4 channel...
4,324
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
54
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
293
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
91
