Modicon M258 Logic Controller
pyea0001
Apr 2013
Singapore
I need to design the system using Schneider PLC but pretty new to it.
The system that I need to design is pretty small system and I am thinking of using Modicon M258 Logic Controller. The main PLC with the extension card will be in central control room but there is a case that I need to have at least one remote I/O (no CPU) in the field.
How can I communicate the Main PLC with Remote I/O?
Is Schneider ethernet module can use for RIO communication?
Thanks you
I don't think these are designed for controlling remote IO over Ethernet. I think you can do message blocks and read IO (ModbusTCP if I recall correctly) but there is no easy method such as IOscanner or using EtherNet/IP class 1 communications.
For this platform, I would look at CANOpen IO - Schneider as well as many others make IO for CANOpen and I think that would work fine. The STB series from Advantys has a CANOpen head module.
If you need/want to use Ethernet IO, then maybe switch to the M340 platform, which has more options?
I have played with these a couple of times and note that the software sure looks like Codesys. Nothing wrong with that, but it's not the same as what the other controller platforms use (UnityPro).
Has anyone ever setup this PLC before? I am having a tough time configuring the IP. I've tried DHCP and Schneider BOOTP program with no luck. I...
3,145
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,322
i have plc modicon m258 its CANopen bus not running and give status on SoMachine v3.1 red triangle after i make download to it so please how...
1,797
I got brand new modicon M258, with extra DI, DO, AI, AO cards, part number TM258LD42DT4 willing to trade with ControlLogix 5000.
1,322
We are running into some issues with serial communications dropping out after a few days. When viewing the PLC hosted web page, we found the...
2,367
