modicon micro plc comm port
smithmarc
Guest
S
I need to determine the comm port settings on a Modicon Micro PLC (without manually running through all possible combinations). I have tried the default (standard) Modbus RTU settings along with several variations but I have been unable to connect to the PLC. There is an off brand display attached to the PLC and it communicates if I plug it into either port on the PLC (so I know both ports work). I can communicate to other Modicon Micro 612-00 PLCs with my software and cable so I know those work. I need an application or program that automatically runs through all the possible communication settings to determine the correct comm port configuration. Does anyone have or know about such an application?
I am trying to extract the program from an AEG Modicon Micro 311/01 PLC. I have a VM running Windows XP and I have Modsoft 2.62 running on it. I...
3,400
Hello, I am entering the final stages of the PLC program using a Modicon Micro 612-03 I used a loop calibrator (4-20mA) to simulate the pressure...
7,618
Hi all plz I need ur help, I have a modicon micro plc and the error lamp is flashing (red colour), this happened before from 2year I just changed...
10,863
I have a problem with a Modicom TSX Micro PLC, it is fitted in a Mailing Machine that has been sent to us from another factory. After applying...
19,596
V
Dear All, I want a programming manual of S5 PLC. Can anybody suggest a link for the same so that I can learn more about it. Also I have a PLC from...
7,354
