Modicon Premium Fault
Chris IWO
Sep 2012
Tabubil
33
Hi ALL,
We have a Modicon TSX Premium PLC-Processor TSX PSY1610, which has a "Low Battey Fault" and cannot run
I am searching for the software to program the PLC and how to talk to it
I am searching for the CPU batteries
I need assistance
Thank you
Chris
Contact your local Schneider Electric sales office for both the batteries and the software.
TSX PSY1610 is a power supply not a processor. Look for the code on the processor.
Depending on age it could be Unity Pro version or some older software which i now forget the name of.
If you've never touched these before you might be better off finding a local integrator to help you.
PL7 is the name you are looking for.
OP, it's legacy software and won't run on anything above Windows 7 from my experience, we run it under a VM on XP
So hopefully its a Unity processor which will make things easier
Hi Saffa,
Thanks-will call Schneider Electric for the batteries
sorry the processor part#: TSX P57104
Chris
Hi tragicallly1969,
Thanks for that
Now I know it's PL7 software
Can I also used "unity pro" to prgram-the processor's part#: TSX P57104
What's the cable part# to connect to the "TERM port" on the CPU?
Chris
Hi tragicallly1969,
Thanks for that
Chris
The processor you have is Unity, so you will need Unity Pro to program it, processors with an even ending number are Unity, Odd ending number is PL7
If you want a Schneider cable its part numbers are:
TSXCUSB485 - USB to RS485 Converter, USB to RS485 RJ45 device connection
TSXCRJMD25 - Programming Cable, RJ45 to MiniDin8 (requires TSXCUSB485)
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
Hello All, I'm currently having issues getting a backup rack for a Modicon Premium TSX H5744M to function properly when it is brought online...
1,134
I'm working on a project and have found myself in a situation where I need to use a PCMCIA card (I think a TSX SCP 114) to read modbus registers...
1,774
I am experiencing a very strange problem. I have purchased tsxcusb485+tsxcrjmd25 cable in order to communicate with a Modicon Premium TSXP57103...
4,195
Hi every body, I'm using a Modicon (Schneider) Premium Hot Standby PLC (2 redundant CPU's). My problem is that after the PLC power failure...
2,896
