Siemens
Siemens confirmed that the WinCC Flexible Panels (OP277 in my case) that have the driver for TSX unitelway, can communicate via a TSXSCA62.
So I bought the same tools...
I just don't understand the connections.
This is what I tried:
1. Tried connection with PL7 to the PLC with a TSXPCX1031 cable. The connection in the CPU is configured to MASTER, 9600 bps, ODD, 8 data, 1 stop.
2. Made the connections, but I'm not sure about this.
3. Made an I/O field to write on the variabletag that makes connection to %MW0. Placed an alarmwindow under this I/O field to see System Messages end selected event messages so that the messages are buffered and don't dissapear.
This is the Setup:
These are the connections that I made in the TSXSCA62:
These are the connections that I made in the TSXPACC01:
Questions:
1. Do I have to use the 15 pins port on the TSXSCA62 or can I connect it the way I did, on the terminals ?
2. How do I have to set the dipswitches in the TSXSCA62, these are now set to 1, 2, 3, 4, 5 ON and 6 OFF, both sides... ?
3. I'm I allowed to use a profibuscable and a profibusconnector on de panel side ?
What can I do to get this working ?
In the alarmwindow I get: Tag1 could not be written when changing the value.
Thanks in advance for helping me out,
Kind regards,
Gerry
This is the Setup:
Questions:
Kind regards,
Gerry
