Modicon sequencer
JeffB
Apr 2002
NW Arkansas
79
Hey guys,
I'm writing my first program for a modicon premium plc (tsx 57) I think. Anyway, reading their manual about their "drum switch" (which seems to be translated from french), I don't understand what the time base is all about. Other than that, it seems to work like an A/B sequencer. I'd appreciate any help. Also, anyone ever program a Magelis HMI. Is there much a learning curve with?
God, I love A/B. I've never had to build a rung one section at a time, and I've discovered I can't insert a rung online using this stuff. What a pain in the ***.
I did a Magelis HMI a few years ago on my own, trust me if I can do it you can, they are usually straightforward.
I cant help with the plc involved.
The timer, associated with the "cyclical programmer" drum sequencer, is an elapsed time for the current step (if reset each step) or for the whole sequence. Was this your question?
You can edit, add and delete, rungs on-line with this software, I do it all the time.
What do you mean by "build a rung one section at a time"?
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
124
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
86
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
84
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
312
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
105
