Module for comunication with Modbus TCP/Modbus RTU bridge
Mar 2015
Mariupol, Ukraine
71
Hello!
Would you please advice me which module between 140 NOC 771 10, 140 NOC 780 00, 140 NOC 781 00 can I select to communicate with Modbus TCP/Modbus RTU bridge? I found out in the catalog that all these modules support Modbus TCP IO scanning. But which is the best one for my application?
Any your help I will appreciate a lot :)
Hello everyone! I am using Siemens S7 PLCSIM to test my ladder program. Unfortunately the Communication module can't be tested because there is no...
5,165
114
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
53
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
268
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
126
