Modulus instruction for PLC-5/40
If you haven't got the mentioned processor, and hence not got MOD, then:-
Put a LBL on the rung, then a SUB, subtract your MOD divider once.
On the next rung, test to see if the result is greater than the divider, if it is, JMP back to the LBL
I have to commision a servosystem with S120 Epos function. It concerns a continuous rotating chain that has pusher connected to it. The position...
4,021
Hi there, I'm struggling with a project right now that involves collecting data from power meters in load centers. The data format is Modulus 10...
4,742
Note to all I found a major problem with the RSLogix modulus operator. If you take the modulus of a negative number in RSLogix the result gives...
3,159
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
98
119
