Moeller cpu ps4-201-mm1
They go wrong, they stay wrong.
If you don't have the original program, the software, the lead and a laptop running Windows 95 with a batch file to initiate the serial port then you are out of luck.
It's start again time.
Thank you for replying! When you say Software do you refer to Sucosoft maybe? And the batch file to initiate the port is it not part of it? If not, where can I get it from...
Lead and laptop is the easiest part :)
If you don't have the original program you can go no further.
There used to be someone that could decompile the uploaded code for a fee but that was years ago.
I might have found the program, and I have also found a spare PLC, same type. I could try to upload the program on this spare. Are you so kind to give me some guidance or a link showing the steps to be followed, many thanks.
I have the software, a backup of the program, and the lead.
But for some reason I cannot connect to the PLC...
It's a long long time since I played with KM plc's.
I remember I could only connect with win 95 and a batch file in exec.com or one of those start up files that had to be executed at boot up.
It set up the comms for the serial port. That is: a real serial port.
Do you happen to have another, identical machine with the PLC that works?
If so, it is possible to transfer the program through a memory card (of course, you'd have to find one of those as well...)
Good afternoon ladies and gents. One of my potential customers currently has a Moeller PS416-CPU-300 PLC and we're looking at upgrading to a...
1,374
Hi.can i take back up from ps4-341 moeller cpu that don t have memory card.It seems that i can t .and then how i can remove plc error . ( plc in...
1,221
Does anyone know how to update the firmware on a Moeller XC-201 processor using X-Soft ?? And is it possible to update the firmware with a USB...
3,811
Is it possible to extract and read the code from a PS416 CPU-200 plc without the original source code using Sucusoft S40 V5.02.(or other method) I...
2,935
Hi group, We have a bit of an issue which I am sure you guys have heard before, I did look at the previous threads but could not see if there...
540
