Moeller PLC problem.
DexterIt
Oct 2010
Italy
21
Hello dear friends.Early this morning got to the plant and one of the machine would not start at all.I look at the PLC type Moeller PS4-341-MM1 and the red led was on in the state Not Ready.After some troubleshooting i got to the conclusion that the program is lost.I think the cause is due to the battery lost of contact on the plc pins.
Now i found an floppy disk containing the plc program(not sure is up to date),but i want to ask what program do i need and what cable?Anyone can help me with a link?Thank you.
Fast edit update: Found the name of the program,think is Sucosoft S40.
Still need info about the programming cable.Going to search moeller's website.
Again me guys,still cant find an valid cable to connect to the PS4-341 PLC from Moeller.Is there a way i can make it maybe?Thanks!
i have 8 plc moeller (model 822-tcx) that are networking together. if any of them is turn off, labview Crashed. Are ther any solution to solve...
1,305
Hi/Ciao Guy How are you ? The world situation is not good but never gives up always . I ask you a question on Moeller ( Eaton ) PS4 model . I...
1,479
Dear All, Any one here use to work with PLC Moeller before? We got one old Machine need to see programming inside them. But this is first time...
1,718
Hello, Can I update the version of operation system from version 1 to 2.0. Thanks
1,155
Hi.can i take back up from ps4-341 moeller cpu that don t have memory card.It seems that i can t .and then how i can remove plc error . ( plc in...
1,220
