Momentary vs Maintained In 3-Pos Switch
Dec 2010
Burlington, NC
402
Hey guys, I am looking for your opinions on 3 position push pull switches. When using them for other than emergency stops, is it better to use momentary in or maintained in switches? We use both at different control panels, neither has caused much issue one way or another. Is it perhaps just operator preference or are there real pros and cons to each type?
I'd say it's application dependant.
Agreed.
But one thing I have done and like to do when that type of control is wanted, is to use a version that is momentary when pulled, i.e. Start, then maintained when pushed, i.e. Stop. The reason is that in a large PB console, by being maintained when pushed you know which button was the one that stopped a process. Lights can do that too, but lamps can burn out (or used to...) plus it's an issue when there are 50+ illuminated buttons on a panel.
Jraef, Your reasoning makes sense. Is there any kind of standard or code (NEC, NFPA 79, UL, etc..) that specifies one or the other in certain cases? I have looked and have not been able to find one, but maybe I am looking in the wrong places.
I always use maintained for emergency stops of course, and I find plenty of information on that.
Perhaps in the future as I design panels I will follow Jraef's lead and use maintained as a standard, his reasoning makes a lot of sense.
I've got this PV700+ project designed with a lot of momentary push buttons that needs to be maintained push buttons. I'm looking for an easy way...
2,772
It's been a long time since I played with an old PV1000. With the momentary pushbuttons, is there really no way to let you push/hold a button...
2,957
Hello everyone, Does anybody know if there is a way of simulating the behaviour of a FTV momentary push button on iFix? I am trying to create a...
1,773
I have GE iFIX 6.1. I have several PBs on my screens. I use the "click" option and select ToggleDigitalPoint. But this not what i want. As i have...
1,836
Hi All Could anyone advise me on how to protect the push button on the screen from occasional touch? I've faced up the problem that I can't...
22
6,553
