Momentum M1 + option adapter(MODBUS PLUS)
May 2010
Newfoundland
First time posting. I hope in time I can contribute something back to the forum but as of now my PLC knowledge is quite limited.
I'm upgrading a system that was installed in 2002. Currently its connected to an HMI computer but I need to connect it to the plant's SCADA system (OSI's Monarch). The system itself has 5 slaves (M1 171CCS70000) and a master (171CCC98020). These six PLCs were installed with the Momentum option adapters (172PNN21022) and use MODBUS PLUS to communicate. The problem with this is that Monarch, AFAIK, can't communicate with MODBUS PLUS, just vanilla MODBUS.
There's an RJ45 ethernet jack on the master that is connected to the HMI computer. My question is: Can I use this to talk MODBUS TCP to the SCADA? The manuals list this as a MODBUS port but I don't know what effect the option adapter could have on its communication.
Thanks for the help. Ask if anything needs to be clarified.
Jon
I'm aware that the Momentum RAM needs to be battery backed to hold the register values. But if we backup the application program to the NV Flash...
4,587
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
105
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
92
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
172
I am not too familiar with the Schneider family of PLCs .. but I have a client that wants to upgrade from a Momentum to something newer. They had...
2,480
