Monitor Pro and Unity PLC simulator
Gambrinus
Oct 2005
Riga
248
Is it possible to connect subjects to achieve something like SCADA and real PLC connection? I often used Siemens WinCC connected to PLCsim. It's very useful possibility.
Yes, you can connect Monitor Pro to a PLC Simulator from Unity Pro. It works without any problems.
Hello Gambrinus
Can you tell me how I can connect Wincc to PLCSIM?
HenryLamboo said:
Hello Gambrinus
I found on a German forum the answer. Wincc with PLCSIM for small displays like an OP73 don't work at the moment.
Best regards,
Henry
Hello, How can I monitor that a timer is timing, in unity pro? Like in rockwell the timer will have a .tt bit. This does not seem to be the case...
1,973
I need some help in problem that i have historical trends & alarms in SCADA monitorpro on server station but it's not working on client station...
1,488
I am having trouble finding alarm codes in Client Builder. I have tried to acces the USDATA screen but I cannot configure it. I can create a new...
1,336
Hey Im new to the forum and new to Monitor Pro. I am currently working with a program that has already been designed and has worked for years. I...
1,463
hi every one I face a problem with communicating PLC type Telemecanique-Premium and SCADA Monitor pro ...using Uni telway ....if any one know...
1,898
