Monitor Pro to Excel using DDE communication
ayman metwally
Dec 2003
Cairo
258
Greetings everybody,
I'm trying to establish a DDE communication between Monitor Pro 7.2 and Excel 2003.
I'm configuring Monitor Pro as a DDE server, I added a new Task in the "configuration explorer" under "System" with these parameters:
- Flag: FSR
- Task Name: FLDDESRV
- Path: /bin/flddesrv
Now for the Excel part:
In the formula of one of the cells I should this DDE address:
=FLNAME.FLUSER|RTDB!'tag_name'
It's all stated in "TaskConfigurationReferenceGuide.pdf"
My question is what Does FNAME and FLUSER refers to?
I believe that FLNAME is my application name (e.g. MyStarterApp), Is it correct?
And what is FLUSER ?
any help is appreciated.
Thanks in advance
I know in the Excel helpfile it is said like this:
The following example shows the parts of a remote reference formula and the required separator characters:
default.aspx
A pipe character (|) separates the program name from the document or topic name. An exclamation point (!) separates the document or topic name from the cell range, value, field, or data referred to.
So in your case the FLNAME is the name of the program and the .FLUSER could be the user name to access Monitor Pro.
I'm not familiar with Monitor Pro but I hope this helps a little.
Greetings Webhead,
Yes, This is the standard format of any DDE address:
Application|Topic!Item
I did many DDE/OPC linking before in customized software for different applications, My problem now is that I can't recognize the names that should be used to in the DDE address to link Excel to Monitor Pro.
Anyway, Thanks a lot for replying .. I appreciate it.
Hello, How can I monitor that a timer is timing, in unity pro? Like in rockwell the timer will have a .tt bit. This does not seem to be the case...
1,973
I need some help in problem that i have historical trends & alarms in SCADA monitorpro on server station but it's not working on client station...
1,486
I am having trouble finding alarm codes in Client Builder. I have tried to acces the USDATA screen but I cannot configure it. I can create a new...
1,336
Hey Im new to the forum and new to Monitor Pro. I am currently working with a program that has already been designed and has worked for years. I...
1,463
hi every one I face a problem with communicating PLC type Telemecanique-Premium and SCADA Monitor pro ...using Uni telway ....if any one know...
1,898
