monitor voltage up to 4160VAC
lesmar96
May 2017
PA
520
I've been tasked with a project where we need to monitor the voltage and display it on an HMI and use it for data reporting.
This is on a test stand where the output voltage can be any where from 120 to 4160.
This is on an old machine and currently it has wires that jump off the main output terminals of the test stand and go through and old resistor board (haven't spent much time figuring out what exactly this consists of) and goes into an old Red Lion voltage meter on a 0-300V input.
We would like to replace the old resistor board (if possible). And use a voltage sensor/transducer to give an analog input to the plc so we know what the 3PH output voltage is.
Any recommendations on the best/safest way to do this? What devices would you recommend?
It is all AC. A transformer would be a good option if I can find a small 4160 to 480 transformer.
Thanks for your replies. These are some good options. The smallest transformer danw linked to is pretty big for what I need, but it is definitely a start in the right direction
if you know of a local transformer manufacturer locally you can get a custom made one, as its for indication only the VA rating is small and hence it can be made small. its a simple request for a manufacturer and have had this done a few times over the years in Australia. this way you can specify exactly what you want and get maximum accuracy.
i suggest you get 2 made so you have a spare for future.
Good Afternoon , We have a number of MSR127 Safety Relays on various machines. We had an issue a few months ago that we had a EStop...
3,750
A little off Topic. I am looking to get a small Circuit designed. Unfortunately I have been a little too long out of the raw electronics area. So...
5,184
I have a voltage low led on in my voltage monitor section. This has enabled the basp led to turn on along with an error light at a cable...
1,342
Hi All, Thanks for the great help... here I go again... I need to monitor the power supply voltage going into sliprings, basically from a 24v...
6,415
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
106
