MotionView Onboard Indexing
unsaint32
Oct 2012
minneapolis
365
Hi, I'm a maintenance guy studying to be an automation tech. I was exploring MotionView Onboard for Kinetix 300. It's for a extruder which is not running at the moment. The PLC is Compactlogix and programmed with RSLogix 5000. I was trying to figure out what command makes the servo motor start indexing.
I opened the Indexing screen, and pressed the "Start Indexing" button. The servo motor moved a little bit then stopped. I think it was executing the indexing 00, and now it is waiting at the index 01. As you can see in the picture I am attaching, the green highlight moved from Index 00 to 01, and the Start Index and Current Index values changed from 0 to 1.
Question #1) Is this going to affect the process at all when we start the extruder?
Question #2) Is there a way for me to restore the indexing status to how it was before?
Thanks.
Does MotionView Onboard software run in Windows 10 I keep getting Unable to Launch the Application. I have put the IP address of the Kinetix300...
11,647
I am using MotionView Onboard for Kinetix300 drive. In the fault history, I see different device times but I don't know what my current device...
2,078
I am using MotionView Onboard (version 3.68) for Kinetix 300. MotionView asks me for a password for clearing fault history. I can't find any...
3,726
I am an automation technician working on Kinetix 300 drives with Motionview Onboard. We have two different setups; - Controllogix 5000 to the...
6,358
Hello All, I am trying to run a Servo Motor using the MotionView OnBoard web interface that comes on the Kinetix 300 drives. I have a Tamagawa...
9,774
