Motor Belt Monitoring in ATEX Zone 1
May 2012
Copenhagen
Hi All,
In know this topic is not an actual PLC-problem, but i hope you guys can help me anyway.
I have a motor placed in the ATEX zone 1 area. From the motor i have 3 parallel belts to a gear that drives a bowl. According to ATEX standards i need to monitor the belts to make sure they do not get warmer than approx. 130-140 degrees celcius.
Do you have any ideas to solve the problem? Or,
knowledge to a solution or a brand that sells this kind of service?
*** |bowl gear
***| motor
Hope you can help, thanks.
If it is truly a "standard" that the belts must be continuoulsy monitored (I'm skeptical) I'd suggest contacting the bowl vendor and ask abouth their normal practice.
Your question suggest an installation in Europe (ATEX). So for the electrical aspects (the motors, ect...) you should look at the European standard EN 60079-14 that notably require the complication of a verification dossier.
For the mechanical aspect there are standards under the ATEX directive, for a complete list see:
http://ec.europa.eu/enterprise/poli...s/equipment-explosive-atmosphere/index_en.htm
I would start to look at EN 1127-1 and then the standards in the EN 13463 series.
Regards
Vincent http://linkd.in/ExConsult
Hello, I have a servo motor running a conveyor belt system. I do not have the exact circumference of the head pully and therefore I get some...
1,436
I had trouble for a week trying to get a Marathon Symax Motor autotuned to work with a Powerflex 753 drive. I solved the problem and thought I...
62
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
317
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
252
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
354
