motor torque question
irondesk40
Jan 2008
nc
630
have a question. Hope i can ask it so it makes sense.
Have a gear motor that is rated at 650 lb_in that turns 47 RPM at max speed.
Need to use this existing motor in a machine and turn a roller approx 115 rpm at max speed.
Gear motor has a 5 inch sprocket on it. If i put a 2 inch sprocket on the roller then the ratio would be 5 to 2.5 Would the the roller with the 2 inch sprocket turn at 47*2.5 = 117.5 rpm for the roller if motor running max speed.
Also, since the motor is rated at 650lb_in and the ratio between the sprocket that is currently on the motor and what will placed on the roller is 2.5, would that cause a difference in the amount of torque that would be availiable at the roller with the 2 inch sprocket.
Thanks for any advice or reply.
Thanks Steve
That was what i was trying to explain to a mechanical so called expert. He kept telling me that it would cause more torque to be availiable at the roller with the 2 inch sprocket, but from what i remember and its been over 35 years since i was in school, just did not believe it.
Think of the two sprockets with a chain between them. In your case, the shaft with the 5" sprocket has 650 in-lbs of torque. That means the tension in the chain is 260 pounds (650/2.5).
That same tension is at the 2" sprocket, but now it can only develop 260 inch-pounds of torque.
This kind of question seems to come up often.
This is really a First Law of Thermodynamics question. The energy and power has to be the same all the way through a system. (Less friction losses, of course. This energy isn't lost, it just turns to heat.)
Torque is always inversely proportional to speed. If you slow your shafts, you increase your torque.
T = hp x 5252 / rpm
In the above T = Torque as ft-lb
We have aspindle that we drive with Siemens Sinamics S210 servodrive and servomotor1FK2104-4AF10-0MA0 and gearbox...
1,644
Why it is said Maximum torque of induction motor is inversely proportional to frequency square ? Maximum torque formula for induction motor is...
4,521
I have an application where I am camming a rotary axis to a master axis driving a web material. The cam profile is fairly simple. The axis is a...
1,773
trying to understand torque. thought it was the vfd. it was a two speed motor. torque seems to be more a product of the motor instead of the vfd...
1,408
Apologizes in advance for a newbie question. In VFDs, there is speed input and torque input. What symptoms would I see on a 3 phase induction...
3,650
