Move String with SFC20 STEP7
Sergihno
Oct 2016
Ukraine
70
Hello everyone!
I'm moving string value from DB to Q area for displaying it at WinCC.
I see some value is presented in DB in Variable Table (TAB).
I move string value using SFC20 "BLKMOV". RET_VAL = 0.
But there is an empty field for text in WinCC.
Have you checked that the 2 first bytes in the string are correct?
The first byte of the string contains max length and the second byte current length of the string they must be correct in order for WinCC to display the string.
This is the first 16 bytes of DB where the text have to be.
Of course you can read any address area with a CP5512 in WinCC v7.
You must have setup the communication completely wrong.
It's working. I use PROFIBUS DP.chn communication driver. I have only "Input" or "Output" modes and then you choose type of tag.
Will the CP5512 work with "Simatic S7 Protocol Suite.chn" WinCC communication driver?
Because only using this driver the all data area is avaliable including DB.
There must be another kind of driver. Probably "Profibus" without the "DP".
I dont have personal experience with WinCC, but I am certain that it is possible to access DBs via Profibus.
Study the manuals for WinCC.
After you set your pg/pc interface- you setup WinCC here
See below
You should have 5512 and not PC adapter like mine
Hi, I need to receive data via a DPDP coupler. On the other side it's simatic doing blockmove. On TIA side it's like blockmove doesn't work on...
959
Good Morning , I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to...
2,409
Hello! Sorry, my english is poor:rolleyes: Please tell me how to remove the line from the file. The library TsSistem no suitable function. Can be...
3,007
Hello, I am trying to move a data DB2.DB Type String [10] to another DB1.DB Data Type String [10] in LAD or STL. Have anybody done this? Move/...
1,826
I am using SLC500 how do you move ASCII (A10) into a string (ST9)? I tried cop FLL and no go Thanks
2,210
