Moving RSLogix 500
It is possible and allowed in some circumstances.
The first thing would be what kind of Activation it has.
i.e. Master Disk or FactoryTalk.
Stu....
If you only have a activation for 1 computer then you could do as I do and that is run it on my laptop then setup a remote desktop connection from my desktop with dual monitors to my laptop.
We use the Rockwell dongles which will move the activation to any machine you want to use. Just not both at the same time.
I'm not sure how but I think the activation can be installed on a USB memory stick and moved from computer to computer as bdoutney said. I have also heard there are other ways that are not legal to use on not more than one computer at a time.
Moving on a memory stick is either EVSRI "master disk" or using a RA Dongle
Master disk still works for Logix 500 but may not in future software updates, Logix 5000 it works up to and including V19, V20+ you must use FTA
The Dongle is similar to Master disk in you can carry the activation around in your pocket, the difference is the Dongle method still uses FTA
Of course there are work arounds that are less than legal, however I do not think that would be a welcome discussion on the site
Hello, I have a question for you guys. I have an AB SLC (505) that I am going to set up an alarm register with. I would like to move the...
20
6,404
Hello PLC Experts, I want to do a logic where in an analog value will be captured per second or in any time possible and move that value into a...
1,622
Is there an easy way to move Program Tags to Control Tags. I know I can export and import tags, but can you import exported program tags into...
13,602
Hello,I am pretty new to this and a quick have a question. Got a fairly simple question, On RSLogix 5000 I want to move an analog sample to an...
3,251
Hello all, The task at hand is a little tricky for me... a novice at best... This is all about an alarm and storing data into rs batch. I have...
5,443
