MP270 connecting to a OPc-server
But i don't want the opc-server on the panel
We have a PC which is connected directly to the plc with ethernet.
On the PC there is a Scada program running, and we also have 3 mp277 which i would like to connect to the same database of the opc-server on the pc.
So the data-transfer with the plc is only with the opc-server ande with 3 panels too.
If the connection is via Ethernet, then why not simply configure a normal connection from each MP277 to the PLC ? Unless the MP277 are doing something exceptional, you shouldnt worry about bandwith.
If the connection is via Profibus, then it is a good idea to try and limit the busload.
I think there is a possibility to use the sm@rtaccess option, so that the panels use the PC as a kind of connection server. Mind you that this has nothing to do with OPC. There should be a similar WinCC Flex RT application on the PC together with the sm@rtaccess option to enable this solution. To be absolutely sure that this variant is possible (i.e. MP277 -- PC + WinCC Flex RT + smartaccess -- PLC) I would check with Siemens.
What I do not like about this solution is that if the PC loses the connection, or is simply shutdown, or whatever problem you can think of, all MP277 panels also lose the connection.
I suggest you put an industrially graded ethernet switch next to the 319F and branch out from that to all the MP277 panels and to the PC.
Jesper makes a good point about the data loss, but if you still want to use OPC there is an OPC communication channel already available in WinCC Flexible. Just set it up in the "Connections" settings.
Upon selecting the OPC-connection, it clearly states only PC-runtimes can be OPC-clients. The MP's are going to be OPC-servers. The help-file also suggests this.
Since Dennis needs em to be clients, I think it won't be that easy.
In post #2 I said that InGears OPC servers will work on Siemens MP panels.
In post #3 Dennis said that he didnt want the OPC server on the panel.
So I think it has been debated already.
Hello,
I would like to ask, if anybody has expierence in connecting MP370 with Intouch using OPC Server via Ethernet. I set in device settings 'Act As OPC Server'.
Then in my PC I set in OPC XML Manager: Prefix (e.g MP370) and MP370 IP. Now the same prefix I put in Access Name in field Topic Name, and Application Name: OPC.Siemens.XML.
It didn't work, any suggestion what did I wrong ?
I need to connect a MP270 to 2 CPU's. Can I easily change data of DB's in both CPU's with One MP270 ?
3,810
Hi I have a system where essentially i am connecting an HMI via a switch to the CP443 card. I've set an IP address in the PLC end and an IP...
1,562
One of my client want to communicate MP270(sIEMENS Operator Panel)with ABB AC800M processor .Is it possible
1,087
My new project is to get work instructions on the HMI. I am using a MP270. I have Pocket internet explorer installed on it. I have the files saved...
3,278
Hi all, I have an existing application using a Siemens MP270 that has failed.The MP270 is connected to an S7300 over profibus. I want to try and...
2,911
