MPI addressing CPU314 IFM
jimshack
Apr 2009
Ashford Kent
:unsure: Hi everybody,
Can anyone explain how to change the MPI address on these plc/cpu.
I can change it on the offline program but I'm unable to change it say from 2 to 8 on the plc.
Can anyone help with this please.
You have to download it to the processor from the hardware configuration.
Configure it, like you said you have, and connect the PC to processor's MPI port.
You have to configure the interface using Set PG/PC from the SIMATIC Manager's Options menu. Set it as node 0 (the PC's address), 187.5kbps if you're using a USB adaptor.
Open the hardware configuration and click the download button. It should pull up a window that leads you to the connected processor. If its address has never been changed it should be a 2. Select it, and download the hardware configuration to it.
mpi addressing
I have already establised comms with this plc and uploaded the program to the pc. Ok i failed to tell the pc what node i was downloading to inorder to make the change. Its now doing what i wanted. Thankyou
Hi I Have new CU320 Module (6sl3040-0MA00-0AA01) for sinamis G150. i want to download Backup config. of old CU320 to new Module with PC Adapter...
531
I have a customer that wants us to use a S7-400 PLC. I don't get into Siemens too often (unless I have to). This machine doesn't do much and...
4,983
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,454
Hello guys, I have upgraded the old 318-2aj00-0ab0 cpu to a 317-1ak14-0ab0. After an upgrade there seems to be a communication issue to a HMI...
1,859
Hello automation experts. Do you have any experience with cheaper USB/DP adapters, such as Amsamotion? I would use it occasionaly, mainly for...
1,669
