rob63 Member OP R Join Date Mar 2015 Location uk Posts 69 May 8, 2016 #31 so i need a new card then, thank you for the help. A learning curve i guess...
rob63 Member OP R Join Date Mar 2015 Location uk Posts 69 May 8, 2016 #32 http://www.ebay.co.uk/itm/SIMATIC-S...380686?hash=item4afeadc40e:g:jUoAAOSwubRXJI0C Would this be ok?
Lare Member L Join Date Jan 2006 Location Finland Posts 2,051 May 8, 2016 #33 rob63 said: http://www.ebay.co.uk/itm/SIMATIC-S...380686?hash=item4afeadc40e:g:jUoAAOSwubRXJI0C Would this be ok? Click to expand... Should be, if it is unbroken. CPU support max 8mb card. But you can check still max supported size from: https://support.industry.siemens.co...can-you-use-with-an-s7-300-cpu?dti=0&lc=en-WW
sigmadelta Member S Join Date Apr 2016 Location From Canada - Living in Bulgaria Posts 2,010 May 8, 2016 #34 You will have to try another MMC. You can try to remove the MMC and reinsert it, just in case it is not inserted completely. It should be practically flush with the front of the CPU.
