Online to Siemens S7300 with multiple MPI connection
sohwel
Aug 2005
Kuala Lumpur
53
I encounter a problem trying to get online to a CPU315,
This CPU is part of a MPI network with multiple CPU including a CPU414,
When I do "Upload to PG" and then "View Accesible Node" I have the screen as attached.
As you can see, I can see all the node but the node with MPI=2 is the one display with the CPU information but the other not.
When I try to select MPI=7, it have the "Online connection aborted"
Physically I am using the ETH_MPI converter and connected on top of the MPI connector of the CPU315 that I want to access.
I can upload and online the MPI=2 (CPU414) without problem
Short of disconnecting the MPI connection of the CPU315 and connect directly my adapter to the MPI port. What are my option here?
Regards
Maybe wrong baudrate for the 315.
The 414 has an MPI/DP port which supports up to 12 Mbps.
The 315 has a non-isolated MPI port which only goes up to 187.5 kbps.
Also, be sure to set slot=2 for the 315.
Thank for the fast response, I will try it the next time I go to site again.
Regards
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,179
Siemens S7/TIA v16: "Overwrite if object exists online?" HMI loading message... Thus far, I've just been ticking this box, just to get the HMI...
769
Good Afternoon. I am having a problem going online with S7-400. Attached is the error that I am getting. I have looked at the help file but the...
1,779
Good evening, I am trying to get online with an S7-300 controller. I am new to Siemens. I can view the CPU when connected, and open up the blocks...
1,290
Kindly, we are trying to go online on an S7-300 plc, with profibus communication, using a CP5711 adapter. But when we open the Ladder and press...
783
