MPI resistor switch
haroon1921
Mar 2012
karachi
why The network MPI must have resistance at the end of the line generally included in the connector and activated by a simple switch...
regards
haoon
MPI is a protocol.
Similar to Profibus, Modbus, DH485, etc etc etc.
RS 485 is the underlying electrical interface, ie the physical layer, upon which all these protocols are used.
So to answer your question:
"Ideally, the two ends of the cable will have a termination resistor connected across the two wires. Without termination resistors, reflections of fast driver edges can cause multiple data edges that can cause data corruption. Termination resistors also reduce electrical noise sensitivity due to the lower impedance, and bias resistors (see below) are required. The value of each termination resistor should be equal to the cable characteristic impedance (typically, 120 ohms for twisted pairs)."
Taken from Wikipedia
Hi I Have new CU320 Module (6sl3040-0MA00-0AA01) for sinamis G150. i want to download Backup config. of old CU320 to new Module with PC Adapter...
542
I have a customer that wants us to use a S7-400 PLC. I don't get into Siemens too often (unless I have to). This machine doesn't do much and...
5,040
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,485
Hello guys, I have upgraded the old 318-2aj00-0ab0 cpu to a 317-1ak14-0ab0. After an upgrade there seems to be a communication issue to a HMI...
1,875
Hello automation experts. Do you have any experience with cheaper USB/DP adapters, such as Amsamotion? I would use it occasionaly, mainly for...
1,680
