Mpi
Hello Sourena;
MPI (Multi-point Interface) is Siemens' proprietary network used both for programming the PLCs of the S7-300/400 series and as the backplane communications network for the same PLCs. It is a proprietary protocol using RS-485 standards (actually it is a subset of Profibus). Every partner on the programming network or on the backplane ("Intelligent" modules such as communication processors and function modules) requires a unique MPI address (up to 31 addresses allowed, plus the programming device)so that exchanges can be supported.
MPI addresses are setup in the Hardware Configuration editor of Step 7, both for the CPU and the intelligent modules. As soon as you select a module taht requires a MPI address to insert it in your project, the next available adrress is attributed; you can also select any available address. The addresses are part of the project and downloaded to the modules as such.
You can get an online list of the used CPU MPI addresses on the Available Partners menu (online), and on the Hardware Configuration (Online) view.
If you are asking for a way to fing out the MPI addresses used in a project through programming, I don't know of one. Maybe someone else can help yopu out further.
Hope this helps,
Daniel Chartier
Hi I Have new CU320 Module (6sl3040-0MA00-0AA01) for sinamis G150. i want to download Backup config. of old CU320 to new Module with PC Adapter...
541
I have a customer that wants us to use a S7-400 PLC. I don't get into Siemens too often (unless I have to). This machine doesn't do much and...
5,040
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,484
Hello guys, I have upgraded the old 318-2aj00-0ab0 cpu to a 317-1ak14-0ab0. After an upgrade there seems to be a communication issue to a HMI...
1,875
Hello automation experts. Do you have any experience with cheaper USB/DP adapters, such as Amsamotion? I would use it occasionaly, mainly for...
1,680
