Hi.
I have a task of creating checklists for a plant that contain many standard items.
My idea is to do this in Excel, whereby in one sheet I define the "types of devices" something like this:
In another sheet I will have the actually used devices listed. Something like this:
Based on the common TypeIdentifier, I want to generate yet another sheet with the checks needed with each line one check, something like this:
I have managed to get almost there with using VLOOKUP and INDEX MATCH functions. But working with individual cells is really clunky and time consuming.
Therefore to the question .. any Excel macro guru has something similar, or good hints on how to achieve the above. I have googled a lot, and found plenty of advice, but I dont have the energy to learn another language, and another programming environment, and all the quirks that go with it. So please....
Btw, I had problems getting anything to work with the VLOOKUP and INDEX MATCH until I decided to add a unique number to beginning of the TypeIdentifier, and presto it worked - after hours of trying stuff and searching on the internet for explanations in vain.
Code:
TypeIdentifier Device description Checks required
01_pump Pump 200 liter per hour On/off, leakage, label
02_pump Pump 500 liter per hour On/off, leakage, label
03_pump Pump 1000 liter per hour On/off, leakage, label
05_valve Valve DN20 On/off, leakage, label
06_valve Valve DN40 On/off, leakage, label
10_conv Conveyor 20 tons per hour On/off, guards in place, E-stop
11_conv Conveyor 40 tons per hour On/off, guards in place, E-stop
Code:
Device name TypeIdentifier Device description
M20 01_pump Main pump
M21 01_pump Refill pump
M22 02_pump Backup pump
M30 05_valve Fill valve
M31 05_valve Empty valve
M32 06_valve Clean valve
W11 10_conv Material Transport
Code:
Device name Device description Checks required
M20 Main Pump on/off
M20 Main Pump leakage
M20 Main Pump label
M21 Refill Pump on/off
M21 Refill Pump leakage
M21 Refill Pump label
M30 Fill valve on/off
M30 Fill valve leakage
M30 Fill valve label
W11 Material Transport on/off
W11 Material Transport guards in place
W11 Material Transport E-stop
