shkoko2000 Member S Join Date May 2011 Location cairo Posts 296 Oct 15, 2016 #1 please i want to know if i can apply msg between two processor built at emulator at rslogix 5000. and if yes,what is the communication path???
nhatsen Member N Join Date Oct 2010 Location Argentina Posts 686 Oct 15, 2016 #2 AFAIK you can't send messages via RSLogix 5000 Emulator.
jude Member J Join Date Oct 2010 Location ontario Posts 117 Oct 15, 2016 #3 a long time ago since I used emulator but I seem to remember having 2 processors in the chassis and using produced consumed tags between them
joaco1993 Lifetime Supporting Member J Join Date Sep 2014 Location newyork Posts 237 Oct 16, 2016 #4 In the emulator I think i had trouble, in softlogix I did it with no problem. Actually i did produced/consumed between 2 procesors in the same softlogix chasis, and also between one cntrologix L63 and a procesor in softlogix.
JaxGTO Member Join Date Apr 2009 Location Kalieefornia Posts 1,074 Oct 17, 2016 #5 You could use Excel to map some tags of each emulator Plc. Then make a macro to write them to each Plc. Cloud also use an HMI package to do the same.
