Hi all, I've worked through messaging in both direction in the CPX and ML1100 with help from you guys. Which is much appreciated. I have a similar app, that requires it to be done to a ML1500 and CPX.
How does the NET-ENI affect this process? I had a cursorary look earlier in the week while at the workshop, establishing comms throught the NET-ENI for programming and monitoring was fairly transparent, but a couple of quick attempts at sending a message from the CPX to ML resulted in some kind of comms lockup that required a PLC restart.
Once again, I will need to send and recieve data from each respective PLC in this scenario.
Cheers.
Cheers.
