MSG Scope determined by hardware?
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at the controller scope.
I thought that was a firmware thing so I struggled a bit against it. Since my L71 and the L16ER are both v32 I guess it IS a hardware thing eh?
Interesting. There are so many things that are hardware restricted that I would not have guessed are, like assigning string literals does not work on L7x controllers but does on L8xE. I've not tried to do many crazy things on compactlogix like I have with controllogix, but I am also surprised by the message tags only working in controller tags and not program tags on the L16ER. Have you tried a newer firmware on it to see if this was a limitation of v32 on that hardware? I'm just wondering if they added support for it later on the L16ER (knowing Rockwell, it is doubtful, but never know).
EDIT: I no longer remember what firmware added support for message instructions in the program tags. Perhaps it has always been a L8xE thing. Now I am curious if the L7x allows it too.
I tend to think its a decision based on revenue rather than tech. i.e. if you want this feature then upgrade. There's no money in new firmware.
107
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
192
I'm trying to read/write to an SLC5 with a ControlLogix L71 V35 plc that fails. The exact same code works on an L82S with V32. Is there a known...
300
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
371
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
269
