MSG instruction in an AOI
yuenli
Jul 2015
Philly
Is it possible to insert an MSG instruction into an AOI? It look like it would work but when inserted into an AOI it does not give me access to change the Instance, path and attribute numbers inside.
Yes I do this fairly often. The trick is you have to have a unique controller scoped message tag for each instance of the AOI. To configure the message instruction, access the configuration dialog OUTSIDE the AOI, not inside.
I'd post screenshots, but all my gear is in the office.
I can do that tomorrow. I have a good example of writing to the path, instance, and attribute dynamically as part of a sequence inside the AOI before sending the message.
Hi guys. I see this is a very old post. Was this example ever posted?
I would really appreciate an example like this. To dynamically setup the MSG instruction inside the AOI.
It looks to be doable, but I cannot find a way to read the path from a hardware source and dynamically pass it in to the instruction in the AOI.
Any advice please?
Thanks!
Take a look at Rockwell networks device library in PCDC. Stratix and DLR faceplates use messaging in AOI. Also you can take a look at the Modbus TCP AOI recently posted to the Sample code library.
Basically, you can configure figure class, instance and attribute in your AOI code. But Service code must be done manually and can’t be changed.
Hi all. Long time lurker, first time poster. I'm working on a project to write a program to monitor the diagnostics data in a number of Stratix...
22
7,666
Hallo ! Did somebody ever make an AOI with a MSG Instruction ?? regards Bernd
2,406
97
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
361
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
281
