MT IND 331 Communication to 1769-L18
dmayhugh
Sep 2016
Michigan
48
I am checking to see if Metler Toledo IND 331 can communicate to the CampactLogix L18 other than ethernet. Has anyone used the USB port with a seral adapter for RS232?
I doubt that would work, although I could be wrong.
Why do you want to do that? The Ethernet/IP module and AOP makes life super easy, I use the IND331 with L16's all the time, seems like way too much hard work to try and patch it together with serial.
It was a customer recommendation to use Existing IND331 that was not ethernet. Today the customer agreed to allow me to switch to Ethernet.
Thank you,
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
22
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
132
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
188
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
I am attempting to generate a VBA script within FactoryTalk View SE to open a Google Chrome webpage (PI Vision) when an object is right-clicked...
127
