Multiturn Absolute encoder
Why not buy a profibus version? Do you really want gray code?
This is in EX Zone 1 so need to check if they have sertified for profibus also.
The encoder will be mounted some distance from the PLC, so it
need to go Junction boxes etc... I hope their are spare cabels we can use between the location fro the encoder and the PLC.
If we shall use profibus, must we install new cabel from AB and maybe use fiber and OLM`s?
I just thinking "high" here :)
Thank you for inputs / assistants everybody.
Hi everyone. We buy servo motors and there are 2 options of encoders. Incremental SinCos hiperface singleturn encoders and Incremental SinCos...
2,302
Hello. An absolute encoder on a rotary axis gives values in range -2147483648 to 2147483648. When value is > 2147483648 , the encoder value is...
20
2,307
I have 2 Absolute Encoders 8192 steps per Rev. (Model TR Electronic CEV65m-11003) These Encoders communicate to the PLC5-60 via Parallel push/pull...
1,519
Hello, First thank for all the help i've gotten through this forum over the years reading others threads. I'm having an issue with Kinetix 5700...
5,926
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,173
