Mvi56mcm
wilsonzhu
Jan 2008
vancouver
278
Hi all,
How to configure prosoft MVI56MCM as both master port( port 1) and slave port(port 2) in Controllogix. I want slave port to provide 0xxx, 1xxxx, 3xxxx and 4xxxx for master reading, and 4xxxx also for master writing. According manual, if set the bitinoffset, wordinoffset, outoffset and holdoffset, 4xxxx can only be for master writing. and another questions is how to be not overlap the data with master port?
Thanks?
I did not understand your question.
Please explain again which functions you want each port to provide.
It would also help to provide the Modbus address ranges and sizes that you need to support on the Slave Port.
In the Manual, 0-600 for WriteData[0-599] and 1000-1600 for ReadData[0-599]. if I configure port 1 as master and port 2 as slave(mode 1)on different modbus network, and I need slave port to provide 40001-40100 for master reading(fuc 3) and 40101-40200(fuc 16) for master writing, 10000-10160 for master reading(fuc 2) and 0000-0160 for master writing(fuc 5). How to configure slave port2 to offset these address to ReadData and WriteDate? and the Rest data array is for master port1.
Thanks a lot.
I am trying to set up a Dev address in a ProSoft MCM module. This module is acting as the master. The Modbus of the slave address is 7566 in a...
1,274
HI , I am using MVI56MCM Modbus module for COntrolLogix . I need to Read/Write data with GE PLC. But my STATUS LED on MVI56MCM Module is still...
3,278
Hi all, I set one port(RJ45) for modbus slave and one port(RJ45) for modbus master in prosoft mvi56mcm card for controllogix. I want to test these...
1,723
Hi all, I use prosoft MVI56MCM in controllogx L62 as modbus communication card. I download addon instruction from prosoft website and...
2,500
