MVM and STOD in Logix5000?
wendaiyu
Jun 2014
toronto
87
Hi, folks, how’s going?
On our one production line, we use AB Logix5000 as main plc and others as slaves.
We name slave plc program as “NEW_MUSTANG”, then send this name to Logix5000.
(plz check the attachment), I am confused about Logix5000 program:
1, in the first “MVM”, why the “Source” is 17742 and the “Dest” is N?
2, in the second “MVM”, why the “Source” is 24407 and the “Dest” is W? not M?
3, in “STOD”, why the value of “Dest” (N15[0]) is 0?
4, if we want to move/transfer “23” to N15[0] when we are running “NEW_MUSTANG” program, how can we program? Chang “NEW_MUSTANG” to “2NEW_3MUSTANG”?
Thanks a lot.
I will try to explain
First the 17742ins not the source it is the value stored in the source
the same for the 24407 and the N and W they are all the values in the tag
it looks like the tags are all char type or string types I can't quite make it out
follow the line source_____ Mask______ Dest___
I hope this helps
other may be able to better explain it.
Sorry, my bad. I checked other program names and found if we change "NEW_MUSTANG" to "203-NEW-MUSTANG", then we can get value 23 and the problem will be fixed.
Thanks for help.
I'm having to make an AOI to use with a generic ethernet device because the manufacturer does not provide an AOP. I just want to do a sanity check...
1,265
Hi All, I know this is probably a strange question, but does anyone know what would be faster between a MVM and AND instruction? I...
1,432
hi all, i have another problem with my unity conversion from rslogix500. i have a MVM (masked move) that i need to program into my unity program...
1,265
Seeing some irregular behavior with my MVM instruction Either that or i dont get how it works? :) I am moving an INT Lets say for arguments sake...
3,285
In an effort to configure BCD switches on my CompactLogix input module. I thought the MVM (masked move), in Studio 5000, instruction might be the...
4,362
