N-tron 500 vs 700 series switches?
Paul351W
Mar 2008
Northern Illinois
154
I'm just getting into the CLX Ethernet communication world and have been reading up about managed switches on here. I was wondering when it would be necessary to use a 700 series switch over a 500 series?
I am setting up a new test stand with an L62 processor, 2 HMI's, 6 remote racks (one of which contains another L62 processor), and the potential for a couple Ethernet communication adapters.
Due to physical layout I was looking at getting a 16 port switch for the control room, and a 4 port for a remote enclosure, both managed switches. The ethernet is going to be a closed circuit for test control, I have another ENBT module installed to connect with the building network.
The 500 series, especially with the -A firmware, was a good sturdy managed switch. I especially like that the features that helped make EtherNet/IP work well are enabled by default.
The 700 series are just newer and a little more feature-rich. They have a web-browser interface instead of just a serial console. They support SNMPv3 instead of just v1 and v2. They have the Rockwell Automation CIP object preinstalled.
I don't know how much of a price difference there is. If price wasn't a consideration I'd get the 700 just for the convenience of the HTTP interface.
List pricing for the 500 Series range from $800 to $1500.
List pricing for the 700 series range from $1800 to $3200.
You'd be able to get around a 10% discount from an authorized distributor.
From N-Tron Online store: 516TX-A $1050, 716TX $999. In my experience the 700 series are less expensive than the equivalent 500 with the -A firmware.
Hi guys Do you have some experiences with Power Analyzers such as Siemens SENTRON PAC4200?.. I have alternative analyzer installed on machine...
2,071
Hey Guys, I need help with configuring the communications between a micrologix 1500 and a nematron hmi. I'm trying to connect it to channel 1...
4,788
i am facing problem with modbus communication between Micrologix 1500 and k-tron controller. Micrologix 1500 is master and k-tron controller is...
4,916
Hello, I'm wondering if anyone here has any experience and information on the Selecontrol 256 PLC at all? I may be able to salvage some and wonder...
172
We have an older Nematron system we are working on and requires some software. The system uses DOS 6.22 and launches Screen Ware 2 software and...
953
