NAIS FPO-C14RS Where Can I Find Software?
kentrobbo
Oct 2007
Melbourne
Hi Everyone,
Wondering if anyone knows where I could find a link to get some software to program a NAIS FPO-C14RS Unit, Even the name of the software would be a help. I dug this unit out of an old box and wanting to get it going but the 3 1/2 in floppies which came with it were corrupted and I could not install the software looks like the software came from GEC ALSTHOM Australia called 7NPSOFTWARE.
Any Help Appreciated
Cheers Kent
o_O
The software comes from Panasonic and I believe the version that you need is FPWIN Pro. Check this link
http://pewa.panasonic.com/acsd/motion-control/fpwinpro.php
If I remember the version is about 450.00 bucks, you may want to contact a Rep to make sure that you get the correct version that supports your processor. it seems like I had ran into some issues there when I bought my copy.
hope this helps...
Travis
does anyone here have good knowledge of the matushita fpo plc's i have one that seems to have 2 inputs that are dead. i need help in testing...
1,509
Hello, I am trying to work with a nais fpo-c14rs and am using FPWIN PRO 5. I have slowly worked through the "on disc tutorial", and have problems...
4,141
Anyone have a cable pinout? The tech support guy at aromat said it was available on the website but I was unable to find it .Would an AB...
4,541
Hello! I have NAIS FP1-C56 Matsushita and after upload code, project Has very much syntax errors. PLC in mode Run signite Error LED. I connect to...
979
Good Morning, I am converting a program from an old Panasonic NAIS FP0. Please see the attached section of logic. Step 637 when the program...
1,731
