Need 3 phase 480v SSR with aux contact ?
2. You can add in logic to make sure the SSR has not failed. For some reason that I don't understand, when an SSR/SCR fails it more often than not fails "closed". With the CT you can measure the current when command is 0, and if the current is not 0 (or close) then you know you have an issue
One good reason to not follow the 'standard' I have seen in machines from Germany and Russia to only use a single pole contactor or SSR for single phase heaters and motors.
I have even discovered [the hard way] only the lead going through the contactor fused, the other lead goes directly from the heater/motor to the service disconnect. That was on a cooling tunnel with a small collection of 240V axial 'computer' fans. With the circuit breaker off there was still 240V at each fan on the other lead. All the single phase heaters on the machine were wired the same way.
Im a mechatronics instructor at a local community college. I have a couple of motor control questions and would definitely appreciate any help...
1,794
There has to be something out there, I just don't know what terms to use to search for it. I need to sense whether or not 240 volt 3 phase power...
35
8,941
This is probably right up a lot of your guys alley. We've recently moved in to a new facility for our company (yay for massive unplanned company...
3,713
Hi everyone, I am part of a senior design group that is building a dynonameter to test shocks. We are ordering parts tomorrow morning and so I...
17
10,105
