Need a rough calculation: Cylinder to Servomotor:
piscis
May 2003
241
I have an application in which two small cylinders with 2” bore and 1.5” stroke with 80PSI of air is gripping and lifting a part.
I need to replace these cylinders with a single servo motor directly coupled to a twin acme screw.
Question:
Can anyone give me a hint on how to convert the cylinder force to servo motor?
How big of a servo do I need to equal the force these two small cylinders have?
Do you think 200 watts servo motor will do or perhaps 400 watts? This application is not for NASA, so a rough estimate will do.
You need to give details of time as well - how long does it take for each cylinder to move through it's stroke and how often does it do it ? The force available from each cylinder is approx 1120N, but that's not much use without more details.
Is the actual magnitude of the force applied by the cylinders critical. Getting an accurate controlled force from a motor/screw needs careful consideration - I'm sure some more advice will be forthcoming.
This is a crawling application, I have 5 seconds to perform the gripping action and 15 second for repeating it.
The Acme screw is 3/4 inch in diameter and 45 inches long.
You need more.
  • What is the lead of the acme screw? (mm/turn).
  • How are you driving the screw? Direct vs. gearbox vs. timing belt? If not direct, you need to know the inertias of each of the elements in the drive train.
  • What power source will you be running on?
  • What is the friction of the screw?
  • When you say crawling application, does that mean your gripper is holding onto something and then the "body" of your device will move forward? In any case, all the forces imparted to the gripper fingers during the cycle need to be considered and calculated back to torques at the servo motor.
  • You mentioned lifting. What do you want to happen when you loose power? Does the motor need a brake?
A picture would be worth a 1000 words here!
The Gripper will grab different size boxes. Let me know if you have more questions after seing the photo below.
Forget about trying to calculate the size of the motor based on the size, stroke and pressure of the cylinders used in the present design. You need to evaluate the mechanism you're going to be using.
I'm afraid your picture alone isn't as much help as you hoped it would be. You mentioned lifting the parts, but your picture looks like a horizontal machine. Are the four vertical devices the grippers? Is the motor you're trying to size the one connected to the horizontal screw and shown in red or one of the four green things on each of the vertical devices?
While selecting the servomotor, you have to consider the stall torque of the selected servomotor. All the connected components of the system should be capable of withstanding this torque, components like shaft key etc.
I appears that your 'lifting force' is being generated by air pressure on the rod side of the cylinder. Be sure to subtract the rod area from the piston area before calculating the lifting force with 80 PSI air.
I would really recommend you go to this site:
http://www.danahermotion.com/design_tools/sizing_selection.php
And get the Motioneering software. It's free.
It will allow you to model your mechanism and prompts you for all the pertinent information required to size a servo system. Even if you don't want to use the Danaher motors, you will be able to determine the torques and speeds required for your application.
Based on your previous description of using a LH/RH acme screw and looking at the picture above, it looks like you are trying to clamp a box between the two angle plates and pick it up with 4 suction cups. You might have to model only half the screw from a motion standpoint but be sure to include all the forces and inertias in your model.
Right now it sounds like you are shooting in the dark.
<disclaimer> I work for a Daneher distributor.
One more thing to know
With your air cylinders doing the clamping, they do not care what size the box is. They just run into the box and stop with whatever force the air regulator is set for. You can even use a pressure switch to tell you when the clamps are in contact with the box.
Depending on the mode of operation, a servo system might care very much that it runs into something. You have to consider this especially if you are tyring to go to specific positions. To really act like an air cylinder you probably want torque.
Then you have to figure out how to limit the speeds and accelertaions (while in torque mode) to get the motion you need.
These are all doable but must be considered in the selection of the components.
Thanks you all for your great insight and support. I believe I have complicated the issue myself. To clear things up I have posted all the drawings to my website with better images than those permitted in this forum.
My customer wants to replace an old dedicated palletizing system with a more versatile palletizing robot.
Here is are images:
http://www.telemetrika.com/RoboticsPage8.html
http://www.telemetrika.com/RoboticsPage9.html
The first photo on the link above shows the first prototype I did to show the customers that a single flap style gripper will work much better than a Vacuum Style Gripper (at least for his loosely shrink wrapped, 40 lbs. bundles)
The testing of the prototype came out with excellent results; we were able to lift all of the 3 different bundle sizes. (For those of you with high speed internet, you can see me lifting one of the bundles in the video)
Since I was able to lift this bundle with those small pneumatic cylinders I figure there must be a way for me to pick a Servo Motor able to do the same job.
I know there are many companies selling servo system eager to help you and do the motor sizing for you, I prefer to acquire knowledge first and then call these guys, and this is why I’m requesting your help, to get the knowledge I need.
I hope that the drawings have answered most of your questions, please let me know if there is anything else I’m missing.
Thanks all!!
ndzied1
Could you or any other brave souls dare to fill all the fields required using that sizing software called Motioneering and post the results along with the data fields used?
I've been watching this thread and really haven't wanted to get in it because there are so many variables.
If you were replacing a servo motor with a cylinder it would be much easier. There are so many variables and things to overlook. Not only must you have enough torque to equate to the cylinder's holding power, but you must look at stall torque, how long the load must be held, the duty cycle of the machine and much much more. It is not just a matter of this cylinder puts out this many lbs of pressure so we need a motor with this much torque.
But the question I have to ask is why? This is more of a cylinder application so why use a servo motor?
http://www.megaupload.com/?d=HG1MOKBD testcode_02_e.zip http://www.megaupload.com/?d=YYUZOVAX InTouch wwsuite lic wwit8_..zip http://www.megaupload.com/?d=SB2RW1UB 0590_s7_200_ppi_test.zip http://www.megaupload.com/?d=ZO4HLKZW MicroWin_3_and_4.zip http://www.megaupload.com/?d=QGIDMFQZ CMM04_3.5_cdmaOne_cdma2000.pdf http://www.megaupload.com/?d=XHRGLP9T 6ZB5310-0JN02-0BA3 - Counti..pdf http://www.megaupload.com/?d=SSSPT7IK brochure_simatic-wincc-flex..pdf http://www.megaupload.com/?d=ZGVJOIP6 Que.CCNA.Practice.Questions..chm http://www.megaupload.com/?d=5RP969Y5 Omron_PLC_Semi_Universal_Ca..pdf http://www.megaupload.com/?d=HIC4NQH0 tip065b.mwp http://www.megaupload.com/?d=PNGH4IOK tip064_2_b.mwp http://www.megaupload.com/?d=VUXL96YH tip064_1_b.mwp http://www.megaupload.com/?d=PDUZUIQX Tip063b.mwp http://www.megaupload.com/?d=46519L40 Tip057b.mwp http://www.megaupload.com/?d=M1PYYP4W tip055b.mwp http://www.megaupload.com/?d=U0XGW7U5 tip054b.mwp http://www.megaupload.com/?d=FUYY8RJ0 tip053b.mwp http://www.megaupload.com/?d=VFK34WCW tip051b.mwp http://www.megaupload.com/?d=ZZY186DG tip050b.mwp http://www.megaupload.com/?d=YTSR6QG4 Tip047b.mwp http://www.megaupload.com/?d=VMK1LELH Tip046b.mwp http://www.megaupload.com/?d=IM30GFP6 tip045b.mwp http://www.megaupload.com/?d=MD3ADTLL tip043b.mwp http://www.megaupload.com/?d=OPSSIHBR tip041b.mwp http://www.megaupload.com/?d=I06E8GEO Tip038b.mwp http://www.megaupload.com/?d=SM03VO5K tip037b.mwp http://www.megaupload.com/?d=UOZGU3LK -_+¡¦»+~2.PMW http://www.megaupload.com/?d=TBGBV60Z S7-200_Unlock.rar http://www.megaupload.com/?d=FFR89LVQ Word_Shift_CirBi.pdf http://www.megaupload.com/?d=GN03678S Word_Shift_Bi.pdf http://www.megaupload.com/?d=E5PAN5YY winac_install.pdf http://www.megaupload.com/?d=34P7F54L cx-simulator_v1_3.001 http://www.megaupload.com/?d=OESCE4MH cx-simulator_v1_3.002 http://www.megaupload.com/?d=GN3H9WKZ cx-simulator_v1_3.013 http://www.megaupload.com/?d=QC9SAFVN cx-simulator_v1_3.012 http://www.megaupload.com/?d=CRDDCJ5Q cx-simulator_v1_3.011 http://www.megaupload.com/?d=EY6SSKYH cx-simulator_v1_3.010 http://www.megaupload.com/?d=9NI12I3K cx-simulator_v1_3.009 http://www.megaupload.com/?d=Y46UB76C cx-simulator_v1_3.crc http://www.megaupload.com/?d=21IJL9K0 cx-simulator_v1_3.008 http://www.megaupload.com/?d=MFTRP2AS cx-simulator_v1_3.007 http://www.megaupload.com/?d=2RPDEO3U cx-simulator_v1_3.006 http://www.megaupload.com/?d=S10PU2EV cx-simulator_v1_3.005 http://www.megaupload.com/?d=JU65BPIO cx-simulator_v1_3.004
http://www.megaupload.com/?d=SXDCNZM4 Syswin 3.4.007 http://www.megaupload.com/?d=GAGPL8R1 Syswin 3.4.011 http://www.megaupload.com/?d=3N7EWJ79 Syswin 3.4.016 http://www.megaupload.com/?d=NIS8AL12 Syswin 3.4.020 http://www.megaupload.com/?d=4KU414S0 Syswin 3.4.crc http://www.megaupload.com/?d=10577A7P Syswin 3.4.024 http://www.megaupload.com/?d=EY1O1WT7 Syswin 3.4.023 http://www.megaupload.com/?d=45M4L2VR Syswin 3.4.022 http://www.megaupload.com/?d=WCKCDW4R Syswin 3.4.021 http://www.megaupload.com/?d=2OBJ8OP4 Syswin 3.4.019 http://www.megaupload.com/?d=UL92AYSB Syswin 3.4.018 http://www.megaupload.com/?d=5GF2GU6C Syswin 3.4.017 http://www.megaupload.com/?d=UBIO8155 Syswin 3.4.015 http://www.megaupload.com/?d=1WXAIUW0 Syswin 3.4.014 http://www.megaupload.com/?d=FFQPJ711 Syswin 3.4.013 http://www.megaupload.com/?d=KY9QKZAA Syswin 3.4.012 http://www.megaupload.com/?d=PEQ1G55U Syswin 3.4.010 http://www.megaupload.com/?d=6UFIBPYU Syswin 3.4.009 http://www.megaupload.com/?d=PAV09JF7 Syswin 3.4.008 http://www.megaupload.com/?d=WNHGTJM5 Syswin 3.4.006 http://www.megaupload.com/?d=ZWPRSSSC Syswin 3.4.005 http://www.megaupload.com/?d=IQV5LPFO Syswin 3.4.004 http://www.megaupload.com/?d=2LTBS5BK Syswin 3.4.003 http://www.megaupload.com/?d=0LN8NDYK Syswin 3.4.002 http://www.megaupload.com/?d=8UQ7BPEZ Syswin 3.4.001 http://www.megaupload.com/?d=3AWO2FL6 cx-simulator_v1_3.003 http://www.megaupload.com/?d=OOPHHBFM Ibh Softec S5_S7_v5-06.001 http://www.megaupload.com/?d=VLMJVQ4Q Ibh Softec S5_S7_v5-06.crc http://www.megaupload.com/?d=YVTQ1Y59 Ibh Softec S5_S7_v5-06.005 http://www.megaupload.com/?d=V1LHJEVJ Ibh Softec S5_S7_v5-06.004 http://www.megaupload.com/?d=HUMH5JVW Ibh Softec S5_S7_v5-06.003 http://www.megaupload.com/?d=C5N5OF7X Ibh Softec S5_S7_v5-06.002 http://www.megaupload.com/?d=K6HA2U05 MCOMPUT_V10 (E).001 http://www.megaupload.com/?d=5K10H8LF MCOMPUT_V10 (E).CRC http://www.megaupload.com/?d=LK1QRBFJ MCOMPUT_V10 (E).012 http://www.megaupload.com/?d=U737AU4E MCOMPUT_V10 (E).011 http://www.megaupload.com/?d=84N5E47H MCOMPUT_V10 (E).010 http://www.megaupload.com/?d=QPDQI44S MCOMPUT_V10 (E).009 http://www.megaupload.com/?d=5MEPN15C MCOMPUT_V10 (E).008 http://www.megaupload.com/?d=CPP88JO2 MCOMPUT_V10 (E).007 http://www.megaupload.com/?d=5G5B9160 MCOMPUT_V10 (E).012 http://www.megaupload.com/?d=BFA0073Q MCOMPUT_V10 (E).002 http://www.megaupload.com/?d=TTLMV8QG MCOMPUT_V10 (E).003 http://www.megaupload.com/?d=3LX38J5U MCOMPUT_V10 (E).005 http://www.megaupload.com/?d=GJRZDYKI MCOMPUT_V10 (E).006 http://www.megaupload.com/?d=J8L9TKOJ MCOMPUT_V10 (E).004 http://www.megaupload.com/?d=G1YW6MT1 Automation Studio 5.0.001 http://www.megaupload.com/?d=4LLRKPKP Automation Studio 5.0.015 http://www.megaupload.com/?d=MPNCWAQF Automation Studio 5.0.008 http://www.megaupload.com/?d=8OT6N84W Automation Studio 5.0.002 http://www.megaupload.com/?d=7M5JO72C Automation Studio 5.0.003 http://www.megaupload.com/?d=T61XKFF3 Automation Studio 5.0.006 http://www.megaupload.com/?d=OU6AW9K6 Automation Studio 5.0.004 http://www.megaupload.com/?d=CR6TTXRY Automation Studio 5.0.007 http://www.megaupload.com/?d=TCQ3FJ7I W3_Investigator.rar http://www.megaupload.com/?d=YICMJRRF Automation Studio 5.0.012 http://www.megaupload.com/?d=C6E6PCQD Automation Studio 5.0.011 http://www.megaupload.com/?d=IXLC7BBV Automation Studio 5.0.009 http://www.megaupload.com/?d=ZWN950K0 Automation Studio 5.0.010 http://www.megaupload.com/?d=AT5VJ4WX Automation Studio 5.0.009 http://www.megaupload.com/?d=4EO5PMZZ Automation Studio 5.0.013 http://www.megaupload.com/?d=5L658PO5 Automation Studio 5.0.crc http://www.megaupload.com/?d=R491GETK Automation Studio 5.0.014 http://www.megaupload.com/?d=Y34OJCCJ 3g3fv.pdf http://www.megaupload.com/?d=88Y3IQ18 Automation Studio 5.0.005 http://www.megaupload.com/?d=SAH55FIZ 3G3RV_I906-E1-1.pdf http://www.megaupload.com/?d=AY4B6P2W 3g3mv_i904-e1-2.pdf http://www.megaupload.com/?d=65WDV6JV 3g3jv_i905-e1-2.pdf http://www.megaupload.com/?d=KBPCF3K4 3g3hv_i900-e1-3.pdf http://www.megaupload.com/?d=RH3BXVP8 Cpus5.pdf http://www.megaupload.com/?d=PC8AKFOS W397-E1-2.pdf http://www.megaupload.com/?d=QR16DQ3F W401-E1-1.pdf http://www.megaupload.com/?d=WRIFJ5PD W396-E1-1.pdf
I have a project ,it need View a CimView screen through the Alarm Viewers; Select the Alarm ID when the point is in Alarm State and appears in the...
1,862
Need good example/sample of aoi RSLogix5000 code to read&write through RS232 port on Need good example/sample of aoi RSLogix5000 code to...
1,842
Hi, Friends doing a program of moeller easy 820-dc-rc plc with MFD-80-B + CP4 HMI display. i need to give the set points in HMI for Cut in and cut...
1,526
We have an ICP DAS remote input console: http://www.icpdas-usa.com/products.php?PID=3293 connected to our router and and am able to monitor our...
2,069
Hi, I've never written a program to gather data from a PLC before so I'm very new to this. I've found a lot of information about the DF1 protocol...
7,945
