Need an Operator Interface for Wago 750-881
johnd_125
Apr 2012
Missouri
146
I've inherited a project that has 5 ea. Wago 750-881 controllers. Each one is connected to a Yokogawa DX-1000 paperless Chart Recorder. The Wagos are also connected back to a single Automation Direct DL06 plc. This is all up and running but now they want a front end HMI application, running on a PC to control the Wago's and possibly tags in the AD plc.
What's an Operator Interface software package that's inexpensive, easy to set up, and perhaps most important, RELIABLE and bug free?
TIA.
If it's not too complex you can use web visualization on the WAGO. The 750-880 is better suited for it because you can store the web pages on SD. We've done 200 I/O projects using only Web Visu and the 880.
Good luck,
(8{)} :) .)
(Yosi)
put a simple internet computer.
give the PLC an address, type this into a browser, and you will see the PLC, here you can go to a web visu you have made in the codesys program (tab3)
Hello, I am looking to order an electrical panel to add to the front of the machine, which will have HMI, e-stop, and e-return. Something similar...
2,634
20
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
209
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
