shahril
Hi, I'm relatively new at SCADA, then i heard of this awesome software. I'm developing a simple monitoring HMI using valve as an output device for my CP1H Omron PLC. I had been trying to use the OmronSerialFinsCom1 as communication tool (using RS232 to usb). But i dint have a clue on setting the right address value on the valve setting to make the pump turn ON (become green) when the actual valve turn ON. the valve PLC Output is at 100.2 I hope that you can help me. Thanks in advance.
