Need help communication to SATTCon 35
void_108
May 2012
jaf
Does anyone have experience to communicate citect to PLC Sattcon 35, I tried to connect to channel 00 PLC (Serial port in front cpu panel) but still no luck.
Where's I can find manual for Sattcon PLC 35?
Thanks in advance for your help
Hello there, I'm practically new to the PLC world, I'm quite familiar with Siemens TIA Portal but I'm currently tasked to program Schneider PLCs...
1,865
Hi; We have Allen Bradley Power Flex750 inverter drive. I want to establish communication between Laptop and drive for which I have a set of...
1,878
hello guys... I have done communication with omron cp1l plc and yasakawa v1000 ac drive now I'm able to write drive parameter from plc program...
3,074
Hi all, My objective is to send data of type int, bool, string etc from the PLC to PC via TCP sockets. I have used the client/server codes to...
2,253
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,563
