I have a situation with an old Barber Colman Maco 8000 controller. The one module in question has 4 analog outputs but they are not rated hi enough to handle the current draw of a proportional hydraulic valve. What I was wonder is it possible to use a PIC microcontroller or something similar to drive the valve. Use 4 analog inputs on the Pic and then program 4 analog outs to follow the same voltage as the input, just have a better current tolerance on the Pic outputs. Or is there any other way? just to do it a cost effective as possible. Any help would be great
