need help for unsolicited messages from compactlogix
syu
Aug 2008
florida
Hello,
I am new to plc and am trying to interface with a compactlogix 1769-L35E through ethernet which is sending unsolicited messages every two seconds. Currently, I have the rslinx classic oem version 2.52 and have it set up with the ethernet devices driver and can see the processor, ethernet port, and local bus adapter.
I created a topic in rslinx with processor type as Logix5000 and unsolicited messages checkbox checked and the rest of the values as default. I then used the OPC Test client to connect and see the message tag values but I see the quality is bad. I did not program the compactlogix but was able to see the message instruction setup through rslogix 5000. I can see that the source element inside message instruction have data. At this point I can not move foward from here. I am not sure if the topic is setup incorrectly or the compactlogix is not sending the message. And if compactlogix is sending the messages how do i see the message?
Any suggestions or help will be appreciated.
60
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
352
177
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
88
