Need help in a small plc program
rohit_plc
Jun 2013
delhi
81
Hello all, I need help in a small plc program in Allen Bradley plc.
Need to generate a 1 second pulse on every ON and OFF of a bit.
Suppose for example a bit b3:0/0 when ON an output (o:0/0)will be on for 1sec. And then OFF and same bit (b3:0/0)when OFF same output (o:0/0) will ON for 1sec. And then OFF.
Use a TON for the ON pulse, trigger with XIC (from your example) B3/0 : if B3/0 is not on for at least 1 second, then seal it in with the TON.TT bit. That same bit is your 1 second pulse for when B3/0 comes on.
Use another TON for the OFF pulse, trigger with XIO B3/0 : again seal it in with the TON.TT bit if B3/0 can be OFF for less than 1 second. That same bit is your 1 second pulse for when B3/0 goes off.
Of course B3/0 can't toggle faster than once per second, or the pulses will get missed, I assume that's not an issue.
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
339
Dear sir. i have one Automation Direct hmi, if you have the CMORE Programming software,i will send you .eap file in email, can you please...
2,446
Hi guys we are constructing a small production line 5 km away from our factory that includes hydrolic presses and small machines. We want to get...
3,954
51
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
