need help in writing program in comparator circuit
jeddai
Aug 2009
ksa
any one can help me to write program in simatic s7.
i have two rotating pulleys with with 4 pulse per turn, i want to detect and give an alarm if pay off pulley are not rotating or not giving pulse. one pulley are attached to the line speed reference and the other to the pay off bobbins.
thanks
Imagine that you are sitting in a room. All you see is a light that is sometimes on and sometimes off. The light is triggered by the pulse from the pulley. Now, what about the action of the light tells you that the pulley is rotating or not? What should the light normally be doing? How are you going to tell if something is wrong? Think about this then let it be a guide.
To add to what bernie carlton said, here's a hint:
I would use two timers per pulley, but there's more to it than that.
Hi friends, I m new to plc programming and i don't know how to write data block in boolean method. I m needed to write data block to...
1,690
Hi friends I am doing my major project and I need your help in writing a Ladder logic plc program. My project is to detect the edges of a block...
4,821
Hi All, I am looking for some help, on writing a logic to control the Power output from a VFD using PID... I will appreciate your help...
2,602
Hi, every body! I have a small project. I wrote programmer control two pump motors by plc s7-300. Now I want to write programmer connect PLC to PC...
4,586
34
