Need help to design a honeywell plc that acts like JLD612 temperature controller.
Mishtavince
Jan 2014
Gulf
19
Hello,
I'm trying to implement a JDL 612 temperature controller in a honneywell PLC that im currently self training myself with.
In simple words to design a plc that works like a JLD612 temperature controller:
So far I've come up with the following I/O selection for the honeywell ML200.
Power supply - 2MLP-ACF1 [ AC:100-240V DC: 5V:3A DC: 24V:0.6A ]
CPU - 2MLI-CPUS [ NON REDUNDANT STANDARD]
THERMO COUPLE INPUT MODULE: 2MLF-TC4S (4CHANNEL)
RTD INPUT MODULE - 2MLF-RD4A (4 CHANNEL)
DIGITAL OUTPUT MODULE - 2MLQ-RY1A
I need help for writing the Ladder diagram:
I can control the temperature using comparison function blocks, but im not sure what to do when it comes to using the PID control. any help to go about with it would be appreciated.
Many thanks in advance.
The shows the ladder diagram for a temperature control, i dont know if its right, so your inputs will be helpful.
The temp control example is based an air condition turning on if the temp reached 24 degrees and turning off if it reached 19 degrees.
Hello all! ok all you programmers out there this guy needs a hand programming an alarm for our phosphoric acid storage tank. The tank has a level...
1,499
Hello all, I have been a long time looker on here and dabbled with some programming, but I now have a serious job that I am looking to get done...
2,614
hello all... my company want using scada system. can some body help me to give me the scada software system where can support Mitsubishi PLC (...
3,299
45
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
345
