[Need Help] VijeoCitect problem when set to TCP/IP
hadihidayat
Mar 2010
Batam
I build the project in Vijeo Citect 7.10. That was fine when run in "No Networking" mode. But when I set to "TCP/IP", the problem occured, I can not change the value of "variable tag" (the button I created to toggle "symbol set" tag was no effect). also, the display in other PC (using web browser) was incorrect (i.e. symbol set filled by grid).
Any suggestion?
This problem occurs because the server address has not been set.
with Vijeo Citect,
1. from Citect Editor, menu Servers, Network Adresses,
a. create address name,
b. set IP = IP PC server.
2. from menu Servers, IO server, set Network Address to the IP of Network Address on step 1.b.
3. do the same for Alarm server, Report server dan Trend server.
4. Pack
5. COmpile + Web deploy
6. Run
with Browser,
7. do web deployment for this projek.
Hope this help you.
34
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
344
171
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
74
