Kommissar_Nance
This is my first post on PLCS.net. It seems like most of the topics are hardware based issues, but I am looking someone whom is willing to help me figure out a logic problem. I will try to describe my issue as best I can. I am using Rockwell Studio5000 v32. I thank you all in advance for your time.
I work at a plywood sawmill. In this mill we have two dyers that look like really big versions of those conveyor pizza ovens you see at some of the fast-food pizza place. These dryers constantly spit out a 3-sheet row of veneer at a time, onto a conveyor. The conveyor runs into a machine that stacks the veneer.
Recently, our plant manager has decided that he wants both of these dryers to feed the same stacking machine, but separated based on the dryer origin. This is to cut down on space and manpower.
To do this, he has had an overhead conveyor installed that merges the 3-sheet group of veneer from Dryer A, into the gaps on the conveyor between the 3-sheet grouping of the veneer coming out of dryer B. So after the merge you end up with the grouping like this
A-A-A, B-B-B, A-A-A, B-B-B, A-A-A..........and so on.
So in order to keep the two groupings separated, I need to figure out a way to track the difference in product. I have done this by simulating a group. Once the leading edge of the veneer in group A hits a limit switch before the merge point, I simulate a 3-sheet window, and load it into a FIFO.
On down the conveyor, at the point where the veneer hits a moisture meter for sorting, the leading edge of the 3-sheet group of veneer hits a limit switch at the infeed of the moisture meter. The switch triggers the unload my FIFO info and tell the moisture meter "these 3-sheets from dryer A, these from dryer B". I have confidence that this method would work under normal conditions.
HOWEVER, between the merge point and the moisture meter there is a person that occasionally pulls defected veneer into buggy. Since I am tracking the veneer by groups of 3, it does not matter if the employee pulls of the 2nd or 3rd sheet of veneer, but if he pulls the fist sheet, it will affect the point where the switch is made at the moisture meter in feed. This is where I am stuck.
I keep racking my brain of a better way to track this veneer, but so far, nothing. Please help.
